BoschSGS43CO2GB/43 D/W.
  • #19712
    mike412
    Hi Folks,
    This dishwasher is stuck on pump/fill. Waste is conventional/ok, no sign of any probs with float switches. I suspect module (s/c pump triac). Anyone got any other ideas?.
    Many Thanks in anticipation,
    Mike.
    #184248
    gegsy
    Re: BoschSGS43CO2GB/43 D/W.
    Metering unit on l/h side and/or ribbed hose from sump to that unit could be gunged up.
    rocker
    If its fills and pumps at the same time, float mirco switch is faulty. have seen a couple with this fault lately.
    cheers john
    #184250
    mike412
    Thanks for the response Greg.
    I will check when I go back to this job on tuesday. But you can see water clearly flowing through the sump hose and out through the outlet side of the metering tank, both at the same time.
    I will also have a closer look at the waste to eliminate syphoning.
    Cheers,
    Mike.
    #184251
    mike412
    Thanks John,
    Sorry, did not see your response until after I had posted my reply to Greg.
    I will double check on the microswitch and “keep you posted”.
    Cheers,
    Mike.
    #184252
    rocker
    Mike, the mirco switch part No 165256 price £9.78 in case you want to take one with you, save a return trip.
    john
    #184253
    superfix
    I have had quite a few lately with this fault.
    Has always been the pcb.
    Defo worth checking the s/w though.
    #184254
    gegsy
    Iv’e never had a float microswitch fail 😕
    mike412
    Feedback…
    It was the module.
    Thanks Everyone who posted a reply.
    Mike.
