Hi, I have one of the above and the programme is stuck on wash, I have check the following:
1, The circ pump and impeller is turning freely and runs when switched on
2, I have checked for gunge in the containers and pipes on the left hand side and they are clear
The only clue that I can give is that the circ pump is noisy when it is turned on.
Could I have a u/s PCB?
Thanks, any help would be appreciated.
I did not leave it on as it was making a lot of noise, the noise was not constant, the pump appeared to pump and then stop pumping as I was watching the water in the tubes at the side, during this time the pump motor continued to run at a constant speed.
It gave the impression that all was not well with the pump, I looked underneath the washer and realised that to investigate the pump the complete plastic under tray would need to be removed, what are the implications of doing this?
Regards
Noise should be irrelevant to programme progress, unless the pump actually stops running. Burnt-out heater relay joint on pcb was an almost standard failure on these machines a few years back – no heat, machine never reaches temperature, programme won’t advance until temperature is reached…….
