#Bosh clasixx 1000
  • #97720
    Issidan
    . Stops after wash cycle so I’ve read all your info on drain pump (very well explained). My Q is how do I get to pump to remove it?
    Thanks in anticipation. I am a novice but keen to try to repair machine. I do have ENR no and Fd no if required.
    iso
    #469189
    would need both number to know which machine you have but you can access from underneath on some machines (some machines have a base cover fitted)
    pull machine out and tilt back at 45 degrees. remove screws holing pump. unclip pump, first remove wiring cable and the the clips holing the hoses
    when u put it back make sure the hoses are in correct position so they wont kink
    Issidan
    Hello and thanks. I received help via Whitegoods email and have replaced pump.
    New problem I think. = no power to machine. Changed fuse and machine started. Soon after it stopped with no lights on front (no power?). Any help would be appreciated.
    Iso
    #469191
    what fuse did you put in ?
