Bosh logixx 7, shuts down for 72hrs between wahes
Home Forums Public Support Forums Help And Support Washing Machine Help Forum Bosh logixx 7, shuts down for 72hrs between wahes
  • #87668
    Ollie_joe
    I have a recurring issue with my bosch logixx 7 integrated washing machine. After completing a wash, if I switch the washer off it will not swtich on again for around 72hrs. When I select a programming using the dial nothing happens, no lights etc. It is as if the washer is dead.
    After approx 72hrs it will work again as normal. The workaround we have been using is to simply not switch the washer off between washes. However this is not ideal as from time to time it will get accidentally switch off, which the results in 3/4 days without laundry.
    Initially I thought the problem might have something to do with the distance between the washer and under sink drainage point. We have had to use an extended hose to connect the washer to the drainage. I suspected that water might not be draining properly preventing the washer from switching on although have found very little on Google etc to support this theory.
    Any suggestions, solutions would be greatly appreciated. Would hate to replace washer only to have the same issues a couple of years down the line.
    #435596
    Re: Bosh logixx 7, shuts down for 72hrs between wahes
    Start us off firstly by stating the model number (ENR) of your machine. 💡
    #435597
    Ollie_joe
    Hi Martin,
    Thanks for replying.
    E-Nr. WIS24140GB/27
    Hope this information helps!
