Bosh over
  • #51093
    MonkeyB
    oven door wont shut, have to push a piece of card on the top of the door to keep it shut, does it just need new hinges? how much would a new door be? random numbers on the side, not sure which one is the model number HBN49s0GB
    FD8108
    ZN534686
    thank you 😀
    #306905
    nomadPaul
    Worn hinges sounds like the problem . The door should close with a solid ‘thunk!’ when the hinges are fully functional. There should be no looseness when the door is in the shut position . Also , when the door is halfway open it should just about hold its position and not jst easily drop.
    Original hinges from Bosch are 267593(R) and 267594(L) and should nearly always be changed as a pair – approx £21:00 each from BSH
    #306906
    Re: Bosh over
    Should be just hinges – part numbers 267593 and 267594. email to spares@ukwhitegoods.co.uk for prices and ordering.
