Bosh SG43E08GB/45 not heating water – HELP!
Home Forums Public Support Forums Help And Support Dishwasher Help Forum Bosh SG43E08GB/45 not heating water – HELP!
  • #15876
    blenky
    Hi popped in for some advice πŸ˜€
    Our 2 year old Bosh has stopped heating the water when running a cycle.
    Not sure if its related but a few days ago the machine made a load bang during a cycle and switched off. I found that the fuse in the mains plug had blown. I changed the fuse and everthing thing seemed fine. However the machine is now running a full cycle with cold water!
    I’ve tried using the repair@ service offered on this site but it found no service engineer in my area (Hove). ANy tips on how to find a reliable service engineer that won’t charge the Earth?!
    #166635
    clivejameson
    Re: Bosh SG43E08GB/45 not heating water – HELP!
    Firstly you might want to check the guarrantee with regards to free spare parts etc and then call BSH Appliancecare (Bosch) who do charge a lot of money (in my opinion) to repair a product, but if the spares are free you will most likely save a few bob in the long run……by the sound of it the heater has blown and this may possibly have damaged the electronics too.
    #166636
    blenky
    Thanks for the reply.
    We had a two year warranty which ran out in December 2005- typical. As far as I’m aware that’s it.
    I’m trying to find out how to locate a reliable engineer in the Brighton & Hove area. I expect it won’t be cheap but trying to avoid the cowboys out there.
    #166637
    gegsy
    Im sure Bosch will do the job FOC at best.At worst you probably will get spares FOC providing you use a BSH engineer.
    blenky
    gegsy wrote:Im sure Bosch will do the job FOC at best.At worst you probably will get spares FOC providing you use a BSH engineer.
    Thanks again for the response.
    Sorry I don’t understand some of the terminology here! πŸ˜• What does ‘FOC’ mean?
    Also where do I find a BSH engineer – just use the Yellow pages?
    #166639
    clivejameson
    FOC = free of charge
    Bosch here http://www.bshappliancecare.com/index.html
