I got the check water light on, in let pipes and out let pipes are clear, replaced the pump and the jugular that’s talked about on other post’s. still getting it. any ideas as to what it is?
Domed float anti-flood safety switch problem of some kind? Something jammed under float? Styrene float dislodged? Pump chamber cover not secured properly?
