Bosh SMS448 Dishwasher
Home Forums Public Support Forums Help And Support Dishwasher Help Forum Bosh SMS448 Dishwasher
  • #75221
    jims
    I have just had the dishwasher stop working!
    It started to fill, the soap dispenser opened and then it stopped.
    I have checked the fuse and the water inlet and both are OK.
    I have tried to start the programme in another part of the cycle and nothing happens.
    The machine appears to be dead!
    Any ideas please
    #394258
    Re: Bosh SMS448 Dishwasher
    i take it you have check the wall socket
    had quite a few jobs where i plugged it in somewhere else and it worked
    jims
    Hi Dave
    Yes checked that and even tried an extension off another socket, one that I knew worked
    #394260
    have you checked whether this unit is covered by the bosch recall
    find the FD number on the dishwasher label ( normally on top of door on stailess part. its a clear label so look carefully you can miss it till you see it )
    if the FD number (1st 4 digits) is between 7901 to 8504 contact bosch to see if yours is covered. this fault may be the reason for the recall
    jims
    Nice thought Dave but it is FD7507. I assume this is the date of manufacture.
