Bosh srs431c12gb/23 drain pump removal
Home Forums Trade Technical & Spare Parts Forums Trade Technical Enquiries Bosh srs431c12gb/23 drain pump removal
  • #63414
    allan73
    Hi All,
    Can someone help a dishwasher novice and tell me how to remove the drain pump on the above.The access seems somewhat poor 😡
    Thanks in advance
    Allan.
    #353700
    Criscold
    Re: Bosh srs431c12gb/23 drain pump removal
    Did one a couple of weeks ago – to only change the pump & not the housing. Remove plinth and metal plate from behind it and also outer door as this helps to give a bit more room to work. Remove transfer pipe from water inlet chamber to sump and the pump should just twist off.
    If you need to change the complete unit I found that the easiest way was to also remove the LH side panel and remove the pump hose from the water inlet unit – attach a piece of string to the pipe – pull the pump out of the rubber bung in the sump and then draw the complete pump with hose and string attached carefully thru the front of the machine – and then after changing pump feed the pump and hose back whilst pulling the string back thru
    -its fiddly but it works
    Colin
    #353701
    allan73
    Cheers Colin 🙂
