Home › Forums › Trade Technical & Spare Parts Forums › Trade Technical Enquiries › Bosh WAP28360GB/01 bearing job
- This topic has 8 replies, 4 voices, and was last updated 12 years, 9 months ago by
allan73.
June 14, 2013 at 3:54 pm #75851
allan73
ParticipantI need to do the drum bearings on this beast and although it looks like a reasonable job, I’m wondering if there’s any thing I need to know before I give the lady a price ?
Thanks in advance for any advice.
AllanJune 14, 2013 at 4:29 pm #396360Martin
ParticipantRe: Bosh WAP28360GB/01 bearing job
You’ll need a bearing kit AND a tub seal gasket kit. Tub needs splitting after tabs are cut off ( new screws in tub seal gasket kit). Arse of a job first time and you have to hope and pray that the drum shaft ain’t scored with the old bearings. If so new drum required or a recall in no time at all……… Viel Glück…!!! 😀
June 14, 2013 at 4:53 pm #396361allan73
I’m sure this tub was screwed together Martin. Are there tabs that need cutting off as well as the screws ?
Allan.June 14, 2013 at 6:21 pm #396362Martin
Probably yes, though not 100{e5d1b7155a01ef1f3b9c9968eaba33524ee81600d00d4be2b4d93ac2e58cec2d} sure, my memory ain’t what it was you see. 😉
June 14, 2013 at 10:57 pm #396363eastlmark
ModeratorRe: Bosh WAP28360GB/01 bearing job
allan73 wrote:I’m sure this tub was screwed together Martin. Are there tabs that need cutting off as well as the screws ?
Allan.
think this is a 9kg siemens tub, no tabs afaik. cannot be more than 18 months old though……June 15, 2013 at 6:05 am #396364allan73
Yes your correct eastlmark. I’ve advised the lady that this m/c should be covered under warranty but this lady is very disorganised and has failed to register or keep her proof of purchase.
AllanJune 15, 2013 at 6:39 am #396365Martin
allan73 wrote:be covered under warranty but this lady is very disorganised and has failed to register or keep her proof of purchase.
Don’t need proof of purchase as the FD number is sufficient to show its age!
June 15, 2013 at 7:15 am #396366Allsorts
Use the EU ruling (1999/44/EC) if you don’t have the guarantee and the machine is under two years old.
George
June 15, 2013 at 8:19 am #396367allan73
I will advise the lady to speak to bosh.
Shame though as looked like a decent job, not too badly gone and in a garage with lots of room to work.
Allan -
