bosh washer
  • #74317
    cornflakes
    model:enr wae2446bgb/7
    fd 8802
    client reported machine made a loud noise and took out rcd
    client cleared /hair grip from drain pump tried once again and nothing happens.
    My visit today
    set on spin cycle, drain pump runs..12 mins timer runs down to 1 minute in less than 60 secs.
    No drum rotation
    tried water fill on 40 degree, water intake ok
    no drum rotation
    drasined machine, rotated drum by hand…clear mechanical noise there
    I am wondering it the carbon brushes have worn, thus taking out RCD
    wanted to see if this is the problem, before removing for inspection.
    No flashing lights appear on LCD screen
    any help welcome
    Graham
    #390982
    Re: bosh washer
    cornflakes wrote:wanted to see if this is the problem, before removing for inspection.
    X-ray eyes eh? Now that would be handy wouldn’t it? I’d go with your suspicions if I were you as I would think you are on the right track there. 😈
    #390983
    Re: bosh washer
    Sounds as if armature may have been damaged. Could be new motor needed. Maybe tried to spin whilst still full due to hairgrip.
    Mike.
