Home › Forums › Public Support Forums › Help And Support › Washing Machine Help Forum › Bosh WFD2471 washing machine
- This topic has 5 replies, 3 voices, and was last updated 11 years, 8 months ago by
BarkbyThorpe.
July 27, 2014 at 8:51 am #81617
BarkbyThorpe
ParticipantJust developed a problem on this mornings wash
The machine was about half way through its wash cycle on a fast spin when it suddenly became more noisier and a small amount of smoke appeared rising from the top of the machine which disappeared after a short while. The machine continued to work if noisier and then I noticed water on the kitchen floor. The wash completed but am wondering what problem may have developed?
Can you help?Many thanks
Mick
July 27, 2014 at 9:12 am #417200Allsorts
ParticipantRe: Bosh WFD2471 washing machine
Check the drum for movement. The noise, the water, and the smoke, could indicate bearing or drum-support failure
July 28, 2014 at 2:13 pm #417201BarkbyThorpe
Many thanks for your reply
Further investigation reveal the drum bearings appear OK with free and noiseless movement and that the water leak appears to be coming from the thermal switch/sensor for the immersion heater attached to the drum…..can you advise if this a known problem? can it be resealed/repairedJuly 28, 2014 at 5:57 pm #417202Allsorts
Make sure the heater is fully inserted, likewise with the sensor, then tighten the nut in the center… not too tight, but tight enough to cause a seal.
It may be wise if the heater has displaced itself to ensure that there was no internal cause, ie a sock or similar engaged in the heater loops…
July 31, 2014 at 11:15 am #417203BarkbyThorpe
Tried all the suggestions with no joy…..
Further investigation after removing the concrete bock and filling the drum with water has revealed that the leak is coming from several small holes/fractures in the moulding of the plastic outer tub…..Your comments please and can you advise a suitable repair/sealantRegards
Mick
July 31, 2014 at 12:33 pm #417204Andy jones
Sounds like a coin or something similar had caused the damage, would probably need the tub replacing
Sent from my iPad using Tapatalk HD -
