Re: Bosh WFF 147S Spin Problems
Two possibilities spring to mind Simon.
1) Water level control system sludged up. This is a white plastic chamber at the 6 o’clock position on the rear of the tub. Remove and clean it and the rubber mounting grommet.
2) Carbon motor brushes worn/sticking in their holders. These are Bosch p/no 154740.
Either of these would give the symptons you describe. Do nothing to investigate without pulling the plug first. :plug:
