Re: Bp5304001m aeg
The installer who installed it for you should have set the clock and run through the different cooking modes while he was there. Any issues after the installation then I would be heading back to the retailer you bought the oven from. An independent retailer should offer all of the above as a standard service.
However if you purchased the oven from the internet and installed it yourself then you will be pretty much on your’e own.
Which section of the instructions are you having a problem with?
Don
