Brand new Indesit DIF 04B1 won’t run any program
Home Forums Public Support Forums Help And Support Dishwasher Help Forum Brand new Indesit DIF 04B1 won’t run any program
  • #92327
    therealcalpol
    Hi there I have just purchased and installed an indesit DIF 04B1 and whatever program I try and run it does the initial drain then fills then drains again and when you open the door the power light is flashing and lights 1 and 3 are solid can anyone help please?
    #450964
    Re: Brand new Indesit DIF 04B1 won’t run any program
    Brand new, this model was first sold in Sept 2013??
    Is the drain outlet hose well above floor level?
    That is not a recognised error code, you should contact the Indesit Company or your retailer.
    Error codes are given by flashing a combination of the first four lights plus the power light.
    #450965
    therealcalpol
    Yes brand new purchased from ao.com
    Yes the drain outlet is well above floor level.
