Re: Brandt Apollo Fridge/Freezer
Yes, they are sealed when new but the internal pipework can corrode causing this which should that be the case it is not repairable. It may also have been damaged when moving it.
You also cannot add coolant without specialist refrigeration equipment I’m afraid.
Chek repairs@ for an engineer if you need one, I’m sure there are a few in Manchester area 🙂
Your suggestion of an Insurance claim may be possible if it was accidental damage and you are covered for this, worth a call I guess, they will send an engineer of their choice to verify normally.
