Home › Forums › Public Support Forums › Help And Support › Cooker And Oven Forum › Brandt Built under double oven bottom oven no Heat
- This topic has 5 replies, 2 voices, and was last updated 20 years, 5 months ago by
bucketheadbob.
November 15, 2005 at 11:19 am #13310
bucketheadbob
ParticipantI have a brandt built under double oven the the top oven works but the bottom oven has stopped working . Nothing but the fan works in the bottom oven. The grill element in the bottom oven doesn’t work nor does the fan element. This fault occured after the grill in the bottom oven was left on for a 2hours by mistake. The grill is not normally used. I wonder what might be wrong? . Is there a thermal trip or something ? Can anyone help me??? 😀 ❓
November 15, 2005 at 11:54 am #154178Dave_Conway
ParticipantRe: Brandt Built under double oven bottom oven no Heat
It may be the cooling fan you can hear running, check the timer (if it has one) isn’t on auto mode.
There well be a thermal cut-out as well, without the model though I can’t check for sure 🙂
November 16, 2005 at 10:43 pm #154179bucketheadbob
Dave, thanks for the reply. The oven is a BRANDT twinline FMT24. I have just tried the oven. It has 2 modes which are fanheat and turbo grill. The fan which is operating is the one by the element in the back of the oven. When I just tried the oven in fan heat mode the grill element came on ???!!!,but the oven element gave off no heat. When I turned it to turbo grill mode, the fan still operates but the grill element was off. This seems to be the wrong way round, so what can have gone wrong ???? I hope you can help me .
Thanks Bob
November 16, 2005 at 11:03 pm #154180Dave_Conway
Has the control knob broken by any chance and is spinning on the shaft of the selector switch indicating the wrong position ?
Apart from that, the selector switch itself may be the cause but I would recommend an engineer checks this for you if the knob is OK, try Repairs@ for one 🙂
If you do decide to have a look yourself, ensure the power is off :zap:
November 17, 2005 at 9:54 am #154181bucketheadbob
Dave thanks for your help.This is vey embarasing to admit, But i seem to have been lead up the wrong path buy my wife 🙁 . The only problem is the fan oven doesn’t work. So it would apprear that the fan oven element has blown. Could you please give me a price for the element.
Bob ( I wish I could erase the previous posts) 😀 😀November 17, 2005 at 11:18 am #154182Dave_Conway
No problem Bob, someone else reading it in the future may find it some halp 😀
The element is available here
