Brandt CFA311WU fridge not working
Home Forums Public Support Forums Help And Support Fridge And Freezer Forum Brandt CFA311WU fridge not working
  • #35570
    jj125
    Brandt CFA311WU Apollo A Class frost free – The fridge is not cooling, it has been set on the highest thermostat setting (6) for maximum cooling but the internal temperature is 13 degrees and that is the lowest it will go. The freezer seems to be working fine. Any suggestions?
    #247164
    helo_75
    thats not usually a good sign, its normally the other way round
    either the pcb is faulty, or the thermistor
    trouble is, the thermistor is foamed in and cant be replaced, so unless you can test it properly, u got problems
