brandt co20fw
  • #7741
    machineman
    f/f dead as a dodo light on/ heater on/ in fridge sounds like the mod to me but any help would be appreciated also where would you source parts .m
    #124914
    clivejameson
    Re: brandt co20fw
    sounds like a board to me too….
    Brandt are prolly the only place to get it…unless Dave or others know better!
    Clive
    #124915
    Dave will be able to get it okay, I’d look it up for you but I don’t have IE on this machine and, annoyingly, AGORA will only accept a connection from IE. 😕
    Re: brandt co20fw
    Had a couple of these that….fire up as you lower the pcb assembly from the roof.
    Undo the screw and lower the front end of the light/pcb unit with power on, if it fires up there’s a broken wire/connector somewhere, not a £70.00 pcb.
    Kevin
    #124917
    Dave_Conway
    Re: brandt co20fw
    Brandt and MFI use the same, well MFI use the Brandt fridge to be more accurate.
    From memory as I ordered one recently for someone the pcb is £55 ex vat and carriage.
    Try Kev’s suggestion, if that doesn’t work and you need one ordered, let me know 😉
    #124918
    machineman
    Re: brandt co20fw
    any idea what the mfi part number is Dave.m
    #124919
    Dave_Conway
    Re: brandt co20fw
    Not off-hand m but it’s one hell of a lot more expensive from MFI than Brandt for some reason 😕
    Over £100 IIRC 😯
    I can check the part number tommorow for you if required though.
    #124920
    machineman
    yes please dave .m
    #124921
    Dave_Conway
    Re: brandt co20fw
    There’s two dependant on the date 😕
    45X8924 – £41.99
    After 15/9/03 – 41X0159 – £35.02
    Probably the earlier one I would think.
