Brandt COA380AU on but not working
Home Forums Public Support Forums Help And Support Fridge And Freezer Forum Brandt COA380AU on but not working
  • #19567
    _Dilz_
    I have a Brandt COA380AU fridge/freezer (less than 3 years old!!). There is power going to the unit (green light on, plus light comes on in the fridge), but neither the fridge or the freezer is working. There is also no sound coming from the compressor at any time.
    One other thing to note, is that every now and again in the last few months, a small puddle of water has appeared on the floor outside the unit on the right hand(hinge side). Don’t know if this has anything to do with it. Up until it stopped working, there were no performance issues and it kept a steady temperature.
    Has anyone got any ideas as to what the problem might be?
    Nick
    #183677
    Dave_Conway
    Re: Brandt COA380AU on but not working
    _Dilz_ wrote:Has anyone got any ideas as to what the problem might be?
    It sounds like the PCB I’m afraid, either that or the compressor has failed but the former is more likely 🙁
    The PCB is roughly £50-£60 so I’d ask an engineer to check to be certain unless you have the means to test it (with the power off). The repairs@ link below should provide one 🙂
    #183678
    _Dilz_
    Thanks for the quick reply. I actually got the model wrong. It is a Brandt CFA361XU. Would that make a differnece to the diagnosis?
    What do you need to test the PCB and where can it be found?
    Nick
    #183679
    Dave_Conway
    _Dilz_ wrote:I actually got the model wrong. It is a Brandt CFA361XU. Would that make a differnece to the diagnosis?
    Nope, very much the same type of unit with a different PCB but roughly the same price 🙂
    _Dilz_ wrote:What do you need to test the PCB and where can it be found?
    If you need to ask that then it’s engineer time in all honesty, I’m afraid we can’t go into specifics for legal and safety reasons 😉
    #183680
    _Dilz_
    I’ve got the old PCB out, do you know where I can get a new PCB from?
    Nick
    #183681
    Dave_Conway
    I can get it for you no problem, an email to spares@ukwhitegoods.co.uk with the model number please and I’ll get prices etc 🙂
    #183682
    _Dilz_
    Just a quickie to say thanks for all your help. Got the PCB today, fitted it and fridge works perfectly again.
    Thanks again
    Nick
