Brandt Dishwasher Leaking
  • #34918
    subs
    VF400. This intergrated M/c had water in the base. After drying it out i checked all hoses and components and found no leaks. What i found was that this m/c has 2 plastic channels underneath the bottom edge of the door on the left and right side near the hindges. Connected to each of these channels is a tube that runs into the base of m/c. When the m/c is washing water is dripping from the bottom left side of the door onto the floor. It also seems to be trickling along the plastic channel and down the tube into the base of m/c. Now for the life of me i cannot work out why it is doing this. I have checked all i can think of. Its not overfilling, spray arms ok ,seal ok, right side looks identical but does not leak. Any ideas anyone?
    Subs
    #244445
    Re: Brandt Dishwasher Leaking
    sure the lower spray arm is not split? often not apparrent until under pressure.
    #244446
    rolf
    Has she changed the tablets she is useing had one that would leak when useing the fancy 5in1s
    #244447
    subs
    Thanks for replies. Im hoping i wont have to go back to this one. I did have the lower spray arm off to remove a lemon pip lodged in hole but must say did not check for split.
    Subs
    #244448
    Lawrence
    I’m with Mark one of the spray arms will have a split in the plastic weld you won’t see it but if you run a blade down it that usually helps to diagnose .
    Lawrence
