Brandt Dishwasher similar to Hotpoint BF41 hinge assy
Home Forums Trade Technical & Spare Parts Forums Trade Spare Parts Brandt Dishwasher similar to Hotpoint BF41 hinge assy
  • #36391
    bobokines
    Hi. I have a brandt built Hygena dishwasher. The model number is missing but I am sure that the same parts are fitted to a Hotpoint BF41
    I need the part number for the fixing bracket that the door hinge straps connect to. It’s the rounded corner unit that lives in the top front corners. I can’t work out what they might be called.
    I have a photo if needed.
    Also I need some adjustable legs.
    Brandt part numbers would be prefered as they are likely to be cheaper and easier to aquire than the hotpoint ones.
    Many thanks
    Bob
    #250833
    Re: Brandt Dishwasher similar to Hotpoint BF41 hinge assy
    Curvy plastic thingy?
    31X9034 – Gutter – R
    31X9035 – Gutter – L
    31X6067 – Black plastic leg.
    bobokines
    Penguin45 wrote:Curvy plastic thingy?
    Er…No Curvy metal thing…
    It’s the bit on top front corners that the door spring adjustments clip onto
    Bob
    #250835
    Oh – hinge kit then – 32X0611 – a whole bag of goodies from Masterpart at £16. Says left and right hand.
    bobokines
    Thanks Chris…
    I am sure I have been here before. I seem to remember I couldn’t find the part before.
    I’ll order the kit and see what turns up.
    Thanks again
    Bob
    #250837
    bobokines
    Just to be sure, this is the bit I need…
    bob
    #250838
    Yes – it’s all bracketed together as a kit.
    goosegreen
    I have fitted a couple of the 32X0611 kits and they don’t come with the brackets. Not sure about the brackets but the adjusters are NLA.
    Goose
    #250840
    try 32×3622 hinge accessory kit, connect have a picture.
    #250841
    bobokines
    Thanks Mark. That’s the one :tup:
    Great stuff
    Bob
    #250842
    bobokines
    Anybody else able to help here please.
    The brackets are no longer included in the 32×3622 hinge accessory kit 😥
    I am sure that they are the same part as used in the GDA BF41 range.
    I wonder if there is a Hotpoint part number?
    Thanks in anticipation
    Bob
    #250843
    Have sent you a picture, looks like you are out of luck Bob. 😥
    bobokines
    Thanks Jim.
    I might be able to get the wire clip to fit on one side and achieve the adjustment for the door weight on the other hinge.
    Thanks again
    Bob
