Brandt Dishwasher Spares
Home Forums Public Support Forums Help And Support Dishwasher Help Forum Brandt Dishwasher Spares
  • #11501
    We have a Brandt DWF371WU/1, type 3.E1.441211210100 dishwasher, it was new the end of 2000.
    It has had 2 new lower spray arms and now the tube that the arm mounts on is worn and pops up letting the water flow bypass the arm. 🙁 Can I get a new one? Some idea of the cost would be good. 😕
    Also the door spring(s) have stopped working, I have not taken it to bits but I guess that I should be able to remove some of the casing to get at them. Does anyone know what I am likely to find when I do? Broken springs, mounts, both or has something just come undone and need reassembling?
    Going on my luck the springs and mounts will both need replacing so cost and availability would be good for these bits as well. 🙄
    #145563
    Re: Brandt Dishwasher Spares
    Your door prob is that the little cord pieces that have moulded end have done a wobbly. I have these in stock. Spary arm parts not in stock but if you wish to give me office a call on 01350 724248 with your name address and the model no of the machine we will try and help. :scot:
