Brandt Dishwasher VF400JU1/B
Home Forums Trade Technical & Spare Parts Forums Trade Technical Enquiries Brandt Dishwasher VF400JU1/B
  • #61025
    M1
    This DW is overfilling. I can opereate the presure switch manualy when the DW is filling and first click the motor turns and starts washing.
    Second click the presure switch then empties all fine.
    I have taken out the presure tube box and cleaned, but it keeps overfilling and never builds up enough presure to switch the presure switch.
    There are two small manufactured holes with little stems in the box and these seem to go nowhere ! the third bigger stem obvoiously links to the presure switch hose.
    What I did find was there was no screw holding the pressure box to the fixing point and it was just a push fit has something else been left off ??
    Any ideas
    #344629
    ben–nevis
    Re: Brandt Dishwasher VF400JU1/B
    Hi M1
    It may be worth checking the flow meter is not sticking as the higher level fill is controled by it.
    If you let me have your email address I will send a training manual.
    Hope this helps
    #344630
    M1
    Just to let you know on this one the Askoll motor had also failed ! Write off !!!
