Brandt fridge freezer
  • #17920
    maltheviking
    Help please.
    Brandt model CFB200WU
    Can anyone give any knowledge to this fault?
    Gutter in freezer blocked with ice, freezer and fridge section not cold enough, compressor only runs for a few minutes, fridge back panel has overall frosting.
    No problem with compressor, I have checked the de-frost heaters for the freezer, fan ok, not sure of the resistance of the freezer thermistor. Measured approx 8k@ -9deg.
    I suspect PCB but I do not have one to swap test, so need to confim that all is ok before ordering one.
    I need wiring diagram and component spec. for this model if anyone can help please.
    #177012
    Dave_Conway
    Re: Brandt fridge freezer
    Wiring diagram on the way but no technical spec on the thermistor I’m afraid 🙁
    The part number for it is 45X8560 if required.
    #177013
    maltheviking
    Thanks Dave your a star again.
