brandt fridge freezer cfa316xu
Home Forums Public Support Forums Help And Support Fridge And Freezer Forum brandt fridge freezer cfa316xu
  • #51668
    gramor59
    can you help?
    I have a brandt fridge freezer that the fridge has a hot part at the back just above bottom shelf.
    above second shelf is cold ish and above top shelf is cold ish,
    this is causing the fridge to be too warm….
    I have just changed out the PCB board and there is no difference even after pressing the boost, the back is still hot 🙁 👿
    is there any other censors that would cause this and can they be changed?
    #308893
    helo_75
    does the back of the fridge flex?
    they were prone to leaking behind the wall, its quite common
    #308894
    gramor59
    helo_75 wrote:does the back of the fridge flex?
    yes it does, but only round the area that is hot/warm,
    its like the heat has seperated the plastic from the insulation
    if this is whats wrong how can it be fixed?
    #308895
    helo_75
    by chuckin it on a skip somewhere
    #308896
    gramor59
    helo_75 wrote:by chuckin it on a skip somewhere
    you mean there is nothing I can do to fix it to work again?
    this will mean I have a £70 pcb for sale now (2 weeks old)
    regards
    Graeme
