Home › Forums › Trade Technical & Spare Parts Forums › Trade Technical Enquiries › Brandt Hob Problems – Is this Induction?
- This topic has 6 replies, 5 voices, and was last updated 18 years, 8 months ago by
laurenceuk.
July 26, 2007 at 3:45 pm #29297
laurenceuk
ParticipantHi,
I am going to this unit soon. I have no model number.
The problem is that non of the rings work. This ocured suddenly.
It is the type that does not have regulators but + & – symbols on the
ceramic top which are touched to increase or decrease heat.Is this an induction type. I have no experience on these so is there any
common faults I should be aware of.Any pointers would be helpful.
Laurence
July 26, 2007 at 4:34 pm #222653bzz67
ParticipantRe: Brandt Hob Problems – Is this Induction?
not sure if this induction,but i had one once with two rings suddenly stopped working.it was just a poor connection in the main switch on the wall.the flex had two lives and two neutrals.no go faults are usually simple to find.
July 26, 2007 at 6:04 pm #222654laurenceuk
Thanks for responding bz but I forgot to mention that the customer said a red light comes on and beeps on the top when a pan is put on it. 😳
So there seems to be supply to the hob – but all things are worth checking.
Thanks again
Laurence
July 26, 2007 at 7:01 pm #222655wench
ParticipantThe only thing that I have had similar to this ended up being a neutral fault on the terminal block. I’d love to hear how you get on with this! 🙂
July 26, 2007 at 7:06 pm #222656robbo1973
depends how old it is if this appeared suddenly and she has used this pan before then there is a fault.if it is an induction hob and she has just got this pan it may not be compatable with induction hobs. if a neon is coming on she has supply check links in term box on hob can knock rings off.
good luck chris.
July 27, 2007 at 2:17 pm #222657pup
check if child lock on
July 27, 2007 at 4:13 pm #222658laurenceuk
Thanks folks,
Great posts.
Went today and it does appear to be the terminal block – all melted and the
links badly burnt.My next question is were do I get Brandt parts as I need a new terminal
block?Thanks again
Laurence
