Brandt range KWE 19X1U trips cooling down
Home Forums Trade Technical & Spare Parts Forums Trade Technical Enquiries Brandt range KWE 19X1U trips cooling down
  • #73257
    mike100
    When small oven used it trips when it is switched off so only cooling fan is running at the time
    Did fit new el to this oven 2/3 years ago.
    Mike
    #386912
    Re: Brandt range KWE 19X1U trips cooling down
    you dont say how you are switching it off but if its a double pole switch its possible for the neutral to break first and in that split second the whole cooker is fed live so if it has a small neutral to earth fault it will trip
    try megger it
    dave
