Brandt WA 9002237/ Model WFH 1671U/ Ident Nr 0020601601
Home Forums Public Support Forums Help And Support Washing Machine Help Forum Brandt WA 9002237/ Model WFH 1671U/ Ident Nr 0020601601
  • #10344
    odnek
    I am trying to locate brushes for the above washing machine motor. The model is the 1600 spin version.
    I would also like to ask if this is a common fault with this Brandt model. I have been lead to believe that motors for this particular model do not last that very long and can expect to change the motor every 3 to 5 years at a cost of around £90. Is this correct?
    This particular machine is only 30 months old.
    #139574
    Re: Brandt WA 9002237/ Model WFH 1671U/ Ident Nr 0020601601
    It is not a fault, it’s a maintenance job. Given that when the machine hits the 1600 loony spin, the drive motor is doing 24,000 rpm, it’s amazing that they last as long as they do.
    Anyway, these:
    http://www.ukwhitegoods.co.uk/modules.p … cts_id=326
    are the common ones that fit most Brandt machines.
    If you have a varispin option on this machine, back it off to 11/1200rpm, you gain nothing above that and simply work the machine harder.
    odnek
    Hi Penguin
    I fitted the brushes on Tuesday and the machine is now working a treat again. Thanks for the brushes and the advice.
    Do you know of anywhere I can get an instruction manual for this machine?
    odnek
