brazing torch
Home Forums General Trade Forum brazing torch
  • #53990
    pup
    what are the good ones to use, makes? any help
    pls for fridges and pluming work
    #317956
    Re: brazing torch
    Brazing
    Not sure how good they are on feathers though Umed. 😉 😆
    #317957
    pup
    Re: brazing torch
    thanks jim ,did you sort your back out ?
    #317958
    Re: brazing torch
    Twas my neck, still get a bit of stiffness at times but have full movement. I will have to get a cushion to lie my head on when working underneath machines. 😀
    pup
    Re: brazing torch
    iadom wrote:Twas my neck, still get a bit of stiffness at times but have full movement. I will have to get a cushion to lie my head on when working underneath machines. 😀
    always lying down on job 😆 what a life
    #317960
    wards
    Re: brazing torch
    rothenburger surefire 2 and mapgas 8)
    #317961
    Dales-Electronic
    Re: brazing torch
    Cant remember the part number but the Turbo Set from qualtex is good and light and does what it says on the tin. Or go the whole hog and get a BOC porta-pak.
    #317962
    spimps
    Re: brazing torch
    Rothenburg spot on.
