Britannia Cook Hood fan and lights not working
Home Forums Public Support Forums Help And Support Britannia Cook Hood fan and lights not working
  • #98494
    jad1451
    We have a Britannia Cooker Hood model P780 – 70A, it is 7 years old. The lights and fan do not work. When I press the light switch I hear a click (I assume the relay) but nothing happens. When I press the fan switch I hear continual clicks, and if I try and increase the speed then the frequency of the clicks changes. Note the fan speed readout on the display (1,2,3, 4) works OK.
    I was thinking I might need to replace the electronic board. But thought I should check with you to see if that is correct ?
    thanks in advance for your help.
    #472605
    I think it’s a lot older than you believe but it does sound like the board has gone and it’s this one used in that hood:
    https://shop.ukwhitegoods.co.uk/08080684-cooker-hood-pcb
    the very fact you can hear clicks means the board is reponding but not letting the power through
    i would turn the board over and check for blown tracks
