Britannia cooker hood lights stopped working
Home Forums Public Support Forums Help And Support Other Appliances Britannia cooker hood lights stopped working
  • #79862
    127john1
    The lights on my Britannia Legato D10 cooker hood have stopped working. The motor still works as normal on all speeds.when the lights worked they did make a humming noise which is no longer present either.
    #410857
    Re: Britannia cooker hood lights stopped working
    it is not easy to diagnose accurately but
    the hum would be a transformer as I am assuming the lamps are a 12 volt halogen
    therefore it could be
    1 the transformer
    2 the switch
    3 the lamps
    127john1
    Thanks for your reply Dave. I think the most likely might be the transformer as when the unit was initially powered up from the isolator it would buzz and flash the lights momentarily,it doesn’t do this anymore either. Thanks again.
    Regards John
    #410859
    dont assume if the power is not getting to the transformer it will give the same result
