Britannia/ ilve D900WMP- Installation Advice
Home Forums Public Support Forums Help And Support Cooker And Oven Forum Britannia/ ilve D900WMP- Installation Advice
  • #82067
    Verrall & Parks
    We are going to install a Britannia D900WMP Built Under Double Oven which is 900mm wide 578mm high for the first time in to an existing kitchen where there was previously a 600mm wide Built under double oven.
    I was hoping someone may be able to give advice in what would be needed in terms of carcase size and fascia panels for us to fit this item.
    (We have the space either side to go up from 60cm to 90cm).
    #418610
    don
    Re: Britannia/ ilve D900WMP- Installation Advice
    The only info I can find on the net is the attached sizing and aperture plan. As for fascias a local kitchen supplier should be able to help you with that.
    I notice it is rated at 4.9kw you need to make sure you have a suitable circuit capable of carrying this load if not an electrician will be required to establish one.
    Don
