Britannia main oven selector switch burnt
Home Forums Public Support Forums Help And Support Cooker And Oven Forum Britannia main oven selector switch burnt
  • #98625
    Murphy24
    I have an old Britannia range cooker (model SI-106T-slx-s, art PD1006MP, serial 05380492) with a burnt main selector switch. When I turn on the main oven the RCD trips. The small oven works ok apart from the light inside the oven which blows when replaced. Since the burning has occurred on position 1, the light only setting, I have disconnected the connections (3 blue wires) to terminal 1 and the switch no longer trips the RCD but nor does it turn on the oven. At the back of the cooker, the insulation is burnt around the light fitting to the small oven. Can you help please? Do I need a new main oven selector switch and should I disconnect and isolate any more of the wiring circuit? I have continuity tested the elements and they all seem fine. Also the lighters on the gas hob aren’t working but I don’t know if this is a part of the main problem. I can’t upload the photos as they are too big.
    #473095
    if the switch is burn it will have to be replaced
    but
    tripping is an earth fault so it could be lots of things
    the burning round the lamp is not burning it will be fat deposits coming out of the oven as fibreglass cant burn
    your tripping could well be the element
    dave
    #473096
    Murphy24
    Thank you for that. Is there any significance/clue in the fact that it was terminal 1? I need to know where to begin looking for a leak to earth.
    #473097
    no significance
    try disconnecting element and see if it trips then
    Murphy24
    Thank you.
    I re-established the power input to the oven selector switch and tried switching the oven on one setting at a time. All of the elements heated up when required by the selector switch. All of the warning lights came on as they should and so did the oven interior lamp. None of the settings tripped the RCD until the oven had heated up to the temperature setting on the dial. Could this still be caused by an element even though they all work? The thermostat tests ok. i.e. continuous until it clicks then open circuit.
    #473099
    yes could easily be an element
