Britannia Range Cooker model SI9TF
Home Forums Trade Technical & Spare Parts Forums Trade Technical Enquiries Britannia Range Cooker model SI9TF
  • #81604
    Impdoms
    Can anyone advise please, to change the oven selector switch on this range cooker, do you have to remove the gas hob, and disconnect the gas to do so. Originally told by customer oven base element had gone, so took on the job. However, we don’t do gas work so may have to can if the answer to the above is yes. Any help would be appreciated
    #417143
    SWERV
    Re: Britannia Range Cooker model SI9TF
    IIRC you don’t have to disconnect the gas, but the top does have to lift off to get at it. Very straight forward though. Some of them come off in sections, so you might only have to lift the left hand side.
    Sent from my iPhone using Tapatalk
    #417144
    Impdoms
    Many thanks for this advice. Will give it a go
    #417145
    snig
    Don’t wish to throw a spanner in the works but i was under the impression if it was a gas appliance then you need a gas certificate. I may be wrong ? Would be interested to know as have been turning away simple electrical faults on dual fuel appliances.
    #417146
    johnmac11
    This has been covered on previous posts, you can work on the electrics if not Gassafe registered.
    general-trade-forum/working-gas-cookers-information-t66145-15.html
    John
