Britannia SI-11XGC-SLK-K Range Oven Timer Dead
Home Forums Trade Technical & Spare Parts Forums Trade Technical Enquiries Britannia SI-11XGC-SLK-K Range Oven Timer Dead
  • #90670
    jontymox
    Good afternoon everyone,
    Wondering if I could obtain a wiring diagram, and/or advice on the above range ovens’ dead timer?
    I deduced that the original timer was faulty, as power is getting to the unit but not working.
    However, I have renewed the timer and it remains dead.
    There are only two lives, and three neutral connections related to the timer, and I’m unsure where to check next…
    Kind regards,
    jonty
    #445561
    jontymox
    Re: Britannia SI-11XGC-SLK-K Range Oven Timer Dead
    Is it difficult/possible to power up the timer to ensure the new unit is not dud?
    Seriously struggling with this problem…
    jonty
    #445562
    SWERV
    I would check the connections on the terminal block. I had one that was exactly the same and it turned out to be a poor contact in the terminal block.
    Merv
    #445563
    jontymox
    will do,
    thank you
    #445564
    jontymox
    Just an update to say i found a broken neutral wire in the loom.
    jonty
