britannia spares ?
  • #65884
    funkyboogy
    model s1-9sx-slx
    got a customer – not been yet who thinks their fan element is faulty …
    anyone know where to get , is there an alternative ?
    cheers ally
    #362256
    don
    Re: britannia spares ?
    Hi ally
    Britannia direct I’m afraid.
    Unless you can make something else fit if it’s just the element that’s failed 😉
    Don
    #362257
    franz
    Connect do some britannia spares including elements – I think your model number should be si9 not s19.
    Franz
    #362258
    SWERV
    I have managed to fit the leisure/rangemaster elements before. Alot cheaper, but you will have to nut and bolt it.
    Merv
    #362259
    funkyboogy
    cheers guys , dont mind nut and bolt method – mind you it will be a cooker out situ for that .. dammmm ..
    looked at connect under manufacturers but brittania wasnt their maybe have a look under model
    cheers ally
    #362260
    franz
    just search si9
    Franz
    #362261
    gandh1
    iirc its a cooker out job anyway regardless of genuine or make do, as im sure theyre screwed in from the rear…
    have used long/thin neck zanussi ones. seem to match pretty well 🙂
    #362262
    loaf
    Zanussi 3 turn ( genny or pattern )
    #362263
    funkyboogy wrote:cheers guys , dont mind nut and bolt method – mind you it will be a cooker out situ for that .. dammmm ..
    cheers ally
    assuming thats the normal range cooker with a gas hob, the hob comes apart easily in sections of each pair of burners. and it is possible to reach down from above and get to the fan element mounts and wires. not easy but have done so in cases where its impossible to remove the range.
    #362264
    gandh1
    funkyboogy wrote:looked at connect under manufacturers but brittania wasnt their maybe have a look under model
    connect can get hold of brit spares but if its a special order, dont bother, go direct to britannia, otherwise connects markup makes it a riduculous price and adds about a week to the delivery time
