Brittania Range – one oven dead!
Home Forums Public Support Forums Help And Support Cooker And Oven Forum Brittania Range – one oven dead!
  • #80459
    paulus22
    With help from you guys I have replaced the circular element around the fan on my Britannia SI-9TF range oven. Because of the crap design I needed to access the rear of the oven to affect the replacement. All went well, I ran the oven up to temperature for 15 mins to burn off the new smell – all OK. Some time later (when I actually needed to use the thing!) the oven will not came on at all. The clock works, the gas ignitors work, the second oven works – but the main oven is dead in all dial positions. Is there a trip/fuse for each oven – and if so where should I find its location? And if not what could be my problem?
    Thanks for any help.
    #412911
    Re: Brittania Range – one oven dead!
    Is there a clock and, if there is, has it been set to “auto”?
    paulus22
    You’re an absolute star! Obviously when the clock was reset it must have been knocked into Auto!! Problem solved – thanks so much.
