Re: Broken door on BEKO WM 1512 S
Hiya,
It’s pretty straightforward to replace the door, even just the glass itself if the door frame is okay which would also save you some money. Usually the door will be supplied in all the bits, door frame outer trim, door frame, handle, latch etc.
Dave will be able to get the parts for you and advise if it is available as a complete unit, just drop him a line on spares@ukwhitegoods.co.uk
As for any glass in the machine, I’d run it through a maintenance wash just to clear it in case but, about the worst that it likely to happen is bits of glass in the pump I expect. There are other things that could possibly happen, but it would be unlikely and unlucky.
HTH
