Home › Forums › Public Support Forums › Help And Support › Cooker And Oven Forum › Broken EOB976 oven
- This topic has 16 replies, 6 voices, and was last updated 13 years, 3 months ago by
chrisjashworth.
December 19, 2012 at 7:21 pm #73157
chrisjashworth
ParticipantHi, I have an Electrolux EOB976 built in oven which has stopped working. I was using the grill the other day and when I went to check it had stopped working. The power light comes on when oven or grill function is selected but when I select a temperature the fan doesnt come on and the temperature light doesnt come on, and also there’s no heat! I thought it was the thermostat so ordered a new one and have just fitted it but still no difference. Any ideas would be very much appreciated so I don’t keep ordering and fitting parts!!
December 19, 2012 at 10:52 pm #386582captaincaveman1
ParticipantRe: Broken EOB976 oven
Possible fault with a contact in the selector switch assuming both fan and element are ok .
December 20, 2012 at 8:49 am #386583chrisjashworth
Is there any way of checking this without replacing loads of parts?
December 20, 2012 at 10:44 am #386584repman
usually a visual inspection of switch contacts is enough.
December 20, 2012 at 5:18 pm #386585Washman
Have you checked that the clock is set to manual and not auto,it has to be set to manual to work.
Washman
December 20, 2012 at 6:36 pm #386586chrisjashworth
okay so just got home from work and checked the contacts on the selector switch but there’s no signs of any damage so not convinced its that, and other ideas? Oh and yes its set manual so no simple fix there unfortunately
December 20, 2012 at 7:01 pm #386587repman
There could be a problem with the timer.You will need to check the continuity across the terminals ,as this will give the same symptoms you describe.
Power off first!!
Jim
December 20, 2012 at 7:06 pm #386588chrisjashworth
I take it I would need a metre to test that?
December 20, 2012 at 7:17 pm #386589repman
Afraid so,or a fuse tester or the like.
Jim
December 20, 2012 at 7:17 pm #386590Martin
Is this a single oven with 3 knobs one of which is a ‘Countdown Timer”?
If so, someone’s not put that 3rd knob onto manual.
December 20, 2012 at 7:22 pm #386591chrisjashworth
yes its a single oven with the 3 knobs but the timer is definitely on manual, if the timer is faulty I’m guessing this could have the same effect? Maybe I should replace the timer and hope its that!
December 20, 2012 at 8:48 pm #386592Martin
I assume you’ve turned the timer between on and off to see if its just a bad contact problem within the timer?
December 20, 2012 at 9:28 pm #386593DrDill
Or set the timer to say 40 mins to see if it works on timed cook?
Sent from my iPhone
http://www.kitchenkitsw.comDecember 21, 2012 at 9:06 am #386594chrisjashworth
yeah tried playing around with the timer but no luck. Timer seems to work and selector seems to work for oven and grill function but not for the 3rd function (whatever that is!!), light stays off when thats selected. Also no light for the temperature which is why I thought it was that! Starting to wonder if it could be the grill element possibly?
December 21, 2012 at 11:08 am #386595Martin
Time to unplug the oven then get out the test meter on the elements. 😉
