Home › Forums › Public Support Forums › Help And Support › Fridge And Freezer Forum › Broken freezer flap
- This topic has 11 replies, 4 voices, and was last updated 17 years, 11 months ago by
madrat.
April 21, 2008 at 12:39 pm #36178
madrat
ParticipantBeeing the heavy handed type I have managed to brake the bottom hinge bit off the top flap in the freezer π
Is there a glue that can stand the cold or am I dumed to get a new one.
April 21, 2008 at 12:58 pm #249910admin
KeymasterRe: Broken freezer flap
Sorry..I’s a new one.
bryan
April 21, 2008 at 1:00 pm #249911madrat
ParticipantRe: Broken freezer flap
:rolls: ok thanks
April 22, 2008 at 2:52 pm #249912SiHa
Before you spend your cash – might be worth a try with some Araldite Instant first. The datasheet says it’s good for -50Β°C to +65Β°C ‘Depending on conditions of use’
I managed to break the hinge off the door flap on our Fridge, and the repair has stood up for a year now. OK, so the freezer is a bit colder, but it’s worth a go I reckon.Before you start, rough up a bit either side of the break with a bit of fine sandpaper and clean with alcohol. Make sure the door is warm – the epoxy will heat on curing, but the cold will slow the process and you don’t want to be holding it together too long. After the initial cure has happened but it’s still soft, mix up a little more and build up a small thickened area on one or both sides to strengthen the joint. After curing, it’s best left ovenight to build up full strength.
Hopefully that should be all that’s required. It’s not the strongest of the Epoxies, but Rapid stays a bit flexible so should not get too brittle in the freezer.
HTH
Simon
April 22, 2008 at 3:33 pm #249913admin
The tube of epoxy will probably be just below the cost of the flap.If it works great if it doesnt then its cost you twice as much.
Bryan
April 23, 2008 at 11:34 am #249914SiHa
r600a wrote:The tube of epoxy will probably be just below the cost of the flap.
Oh π³
TBH, I assumed the flap would be reasonably dear. I also must admit I didn’t factor in the cost of the glue – I already had some. It’s onlyΒ£5 a tube anyway.
Whatever
April 23, 2008 at 12:40 pm #249915madrat
Thanks everyone
A new flap is around Β£10 from e spares.
Will have to remember to be more gentle π³
April 23, 2008 at 8:39 pm #249916gegsy
madrat wrote:A new flap is around Β£10 from e spares.
So what is wrong with our lovely shop@ on the left menu ?? π
April 23, 2008 at 9:08 pm #249917madrat
Absolutly nothing, I tried them first but they dont have anything
April 23, 2008 at 9:15 pm #249918gegsy
If its not there try emailing spares@ukwhitegoods.co.uk , we will always endeavour to find what you need π π
April 23, 2008 at 9:19 pm #249919madrat
I did no joy π₯
April 23, 2008 at 11:10 pm #249920gegsy
Im sorry to hear that and apologies and thanks for trying us first π
