broken refridgerator hinge
Home Forums Public Support Forums Spare Parts Help broken refridgerator hinge
  • #7086
    We have a built in fridge (no freezer compartment) and the bottom hinge has just broken. The manual we have has no indication of the make or model number.
    The other appliances (dishwasher and oven) are diplomat and it is a hygena kitchen.
    can you help.
    cheers peter
    #121311
    BobHope
    Re: broken refridgerator hinge
    Hi Peter,
    the model no will be on the rating plate normaly located on the left hand side wall behind the bottom salad container. sure someone can help you once you locate the model no.
    Cheers Bob.
    #121312
    Peter,
    It is likely that the fridge is also a Hygena/Diplomat and the model number should be located in tha vacinity of the ‘Salad drawer’ 😉
    Once you give us the number we should hopefully assist further with the replacement part you need?
    Dave_Conway
    Does this look like the hinge once it’s been removed ?
    It’s a very common one especially across the MFI supplied range of under counter built in refrigeration.
    You’ll need to let me know if it’s the bottom right or left as they diifer.
    #121314
    Thanks or the model location
    it is a servis(uk) model M781c
    and yes dave the hinge does look like that.
    bottom left
    cheers
    peter
    #121315
    Dave_Conway
    I thought it may be 😀
    You can get one from the shop here if you wish:
    http://shop.ukwhitegoods.co.uk/24600980 … door-hinge
