Re: Broken Servis Fridge/Freezer
Hi – Hope this will help you diagnose the problem – pull the appliance out if its in a unit and kneeling at the back switch the fridge-freezer on. Now listen out for a click (can be up to 30 seconds wait) if you hear a click then you have a defective compressor which is a very expensive repair. If however you do not hear this click then there is a good chance that it is your thermostat which has failed – this is more common and less expensive. The part number for the thermostat is 526012800 or 526012802 both will work. If you require the parts you can order it through shop@ and if you need a service call a local independent can be selected at repairs@ – Good luck
