Starts cycle but after 30 seconds of pumping it stops and the green LED flashes 6 times. I have searched all over this website and others and cannot find out what 6 flashes means. Can anyone help?
I have checked to see if the spray arms are blocked and they are not. I have manually put water in the bottom of it and it gets pumped out ok. I have narrowed it down to a problem with the input of water. Am I correct?
Re: Broken Whirlpool DWF 416 Ikea Built In Dishwasher
jasonwiggins wrote:Am I correct?
Yes ! 😀
F6 is a “no water inlet” problem. It can be caused by quite a few things though. If you have checked the water is OK as far as the machine and all is OK then it’s engineer time to be honest.
