broken whirlpool oven door
Home Forums Public Support Forums Spare Parts Help broken whirlpool oven door
  • #5926
    I have a built in whirlpool oven AKZ104, the all the glass has been broken!
    I have the casing and handle, how easy is it to replace the glass?
    many thanks rob
    #114625
    Rob,
    Most of these modern Whirlpool ovens have the glass bonded to the inner door panel, so that is only available as an assembly. The outer glass is usually available separately, although you will have to recover all fixtures and fittings to put the new assembly together.
    Mr Conway will be able to offer up some prices in the morning; the product no. would probably help things along. Starts 85 or 89……..
    Dave_Conway
    Re: broken whirlpool oven door
    I’m assuming it’s just the outer glass required ?
    As this is a stainless steel model it’s a bit expensive at £91.10 inc VAT plus postage.
    #114627
    is it possible to buy a replacement door,complete? or would a door from another model fit? do you kow a company who might be able to assist?
    many thanks rob
    #114628
    Dave_Conway
    You won’t be able to buy a whole door I’m afraid.
    What would you like assistance with ?
    #114629
    well I guess I’ll have to buy the front bonded glass – but the inner glass could just be cut and stuck – are there any firms that can do this in london? or where i could buy the glass and glue and do it myself
    rob
    #114630
    Hi rob
    assuming this is a built in appliance you could claim on your buildings cover as long as the appliance was damaged iaw your policy…..or..try http://www.flyingtoolbox.com and buy an insurance on-line to cover a broken appliance(there are rules and limits) but it might well be easier than doing it yourself and less costly
    regards
    kevin
    #114631
    Dave_Conway
    Rob, you can buy the inner door complete with the glass for £61.17.
    Better still, try Kevin’s suggestion 😉
    #114632
    If you think I can get a door complete for £65 I’d jump at it!!
    Where can I get it?
    cheers
    rob
    #114633
    Dave_Conway
    Anonymous wrote:Where can I get it
    No Rob, that’s the inner door panel complete with the inner glass only, add to that the outer door glass I mentioned originally then the hinges, then the handle, you won’t be far short of £200 to make the whole door up.
    You must have some parts of the door still surely ? Or did you chuck it all away ?
    #114634
    I see
    I do have all of the door parts only the glass is broken.
    looks like i will have to buy both inner and outer panels to repair the door.
    just like to say thanks for your help
    rob
