Home › Forums › Public Support Forums › Spare Parts Help › Brushes for a Whirlpool AWM8143 (complete with holder)
- This topic has 5 replies, 2 voices, and was last updated 14 years, 6 months ago by
tom-0_0-.
September 23, 2011 at 8:42 am #65238
tom-0_0-
ParticipantHi
I hope someone can help me brushes for a Whirlpool AWM8143.
The Whirlpool service manual states that they are: Part No: 4812 362 48004 Brush, carbon motor CESET. However I have discovered that for my machine that is not the case.The motor has a part number: 461971077351. When I Google this all the hits are in German, sounds like it may be a BAUKNECHT machine rebadged by Whirlpool?
I need 2 brushes and if not the whole brush holder then at least the brass guides as well. The plastic holder has the following number on it: 165 60010 PBT and its got a socket for a spade connector, the position of this socket is important.
Any help would be appreciated I have been searching for this for quite a while.
I believe they are 35 or 36mm (12×5) brushes and I have seen similar on line for Siemens and Bosch machines, problem is they were the brush only and I also need the brass guide as well.
Re the pics of the open holder, ignore the cut on the left, that’s a hacksaw cut to try to make the wrong guide fit. The black pointer is showing where the correct guide should anchor in the holder.
thanks in advance
Tom
September 23, 2011 at 9:00 am #359786don
ModeratorRe: Brushes for a Whirlpool AWM8143 (complete with holder)
It may be easier to post up the bar code number from inside the door frame which starts 8570…….. to help us make a correct identification.
Don
September 23, 2011 at 11:10 am #359787tom-0_0-
ParticipantRe: Brushes for a Whirlpool AWM8143 (complete with holder)
Thanks Don
From inside the door:
12 NC: 857081453900September 23, 2011 at 11:47 am #359788don
According to Whirlpool tech the part number is 481236248434.
You should be able to order them through our shop. An email to spares@ukwhitegoods.co.uk in the first instance should do the trick.
HTH 🙂
Don
September 23, 2011 at 10:19 pm #359789tom-0_0-
Thanks Don, that does look like the correct part number however it’s the carbon brush only. I also need the brush holder as well or at least the brass guides. Can you find a part number for this?
Regards
TomSeptember 28, 2011 at 1:47 am #359790tom-0_0-
Still looking for these brushes. Apparently its a Siemens motor. Any suggestions?
