BT2710SS loss of power
Home Forums Public Support Forums Help And Support Cooker And Oven Forum BT2710SS loss of power
  • #92947
    andynorman
    I have a Baumatic BT2710SS dual fuel range cooker with no power. What started as an intermittent fault where sometimes the gas burner ignition wouldn’t work progressed to the two ovens sometimes cutting out, and is now no power to anything.
    The MCB is not tripped when the controls are used, and the isolating switch on the wall has a glowing LED indicator when the power is switched on so there is power provided, but neither of the ovens work, nor the gas ignition. The green LED power light for the ovens doesn’t come on either.
    Anyone have any ideas what might have failed?
    Thanks.
    #452673
    Re: BT2710SS loss of power
    Main connection failure between wall switch and oven unit by the sounds of it. Time to drag out the oven and check power cable terminal block at the back me thinks.
    #452674
    andynorman
    Hi Martin… thanks for the quick answer… I’ll have a look and see what I can see.
    #452675
    andynorman
    I’ve had a look at the back and that looked fine, so I took the back cover off and the connection box also looked good… following the cables up the back though I came across a lot of scorching around the oven connections, mainly the small one. I’ve attached some pictures although they didn’t stay oriented correctly.
    I’m no expert but I don’t think that should be happening!
    I’m loathe to replace the thing as I’m moving house some time this year and I don’t know what I’ll need in the new place, but is it worth trying to repair?
    #452676
    Judging by those images a thorough inspection and electrical safety testing throughout is the next step. A prudent move would be to seek the help of a local independent repairer to take a look for you.
    #452677
    andynorman
    Thanks again Martin, it’s really good of you to reply. It’s sort of what I thought… I’ve posted a request on here to see if there’s anyone local. I did email a couple of places before Christmas that were in my area, but they haven’t responded. I’ll see what happens.
    #452678
    Hi Andy
    What area are you in ?
    Bryan
    #452679
    andynorman
    Hi Bryan,
    I’m in Ipswich, so a little way from you in Bedfordshire.
    AndyN
    #452680
    Lawrence
    Hi Andy
    I’m in Ipswich
    Ring my office on 01473233533
