Home › Forums › Public Support Forums › Help And Support › Fridge And Freezer Forum › Built-in fridge Schreiber APM6314 door seal gone
- This topic has 8 replies, 3 voices, and was last updated 8 months, 3 weeks ago by
Liz Crawford.
July 13, 2025 at 5:33 pm #103466
Liz Crawford
ParticipantHi. I can’t find a replacement seal for this freezer anywhere. It’s built-in, so will I still be able to get a replacement door or get a whole new fridge? I’m worried that the sizes of these fridges will have changed!!!
July 13, 2025 at 7:24 pm #493279don
ModeratorSchreiber was owned by MFI from the early 1980’s , If I remember this correctly these were available in the mid to late 80’s which makes this approaching 40 years old.
The main company which held spares for this brand, Diplomat and Hygena was a company called AWS who closed down a few years ago. There are virtually no spares available so it really is time to call it a day and replace the appliance.
If you measure the outside wooden doors and count the number of freezer drawers I can point you in the right direction. Also check if there are plastic runners between the decor doors and the appliance doors as there are two different types of hinges available.
Don
July 13, 2025 at 8:09 pm #493280Liz Crawford
ParticipantThank you so much. The outside doors are a weird size – 28 and 1/4 inches x 23 inches. Inside the freezer yhere is a largish top space which should have a folding down flap and 2 drawers. I realise I have put that it’s my freezer that’s faulty . It’s actually the fridge, but the sizing will be the same.
July 13, 2025 at 8:14 pm #493281Liz Crawford
ParticipantPhoto of the door because I wasn’t sure what you meant about the plastic runners.
July 13, 2025 at 9:12 pm #493282electrofix
Moderatorthe plastic runners are part of how the outer door connects to the freezer door
from the look of the photo yours does not have them
if it has runners the outer door is hinged to the cabinet and the fridge door has its own hinges but it looks like your doors maybe using the fridge door hinge for both
July 13, 2025 at 9:38 pm #493283Liz Crawford
ParticipantThank you. You said I should get a new appliance anyway. Do you still think that?
July 13, 2025 at 10:41 pm #493284electrofix
Moderatorwell the fact you cant get spares and the fact newer unit are far more efficient it makes sense
July 14, 2025 at 4:49 pm #493285Liz Crawford
ParticipantThanks. I will do that then.
July 14, 2025 at 5:24 pm #493286don
ModeratorI believe from your sizing you have a 70:30 split integrated fridge freezer. You will need to check any new appliance will take your existing decor doors.
As for the hinging it would you appear you have what is called fixed hinging so your replacement needs to have the same. You can install a freestanding appliance in the housing which would be a cheaper option but you would need to lose the decor doors. Hotpoint and Beko amongst others will fit. Just make sure you measure well before purchasing.
Don
