Built under single ovens – allowed?
Home Forums Public Support Forums Help And Support Cooker And Oven Forum Built under single ovens – allowed?
  • #6478
    Are there any dos and don’ts of having 2 single built under ovens side by side – was thinking of this with a 5 burner hob on top. It’s either this arrangement or else a range cooker.
    #117898
    Technically, I don’t see any reason why not so long as each is in its own housing. Bear in mind though that you will end up, with the carcasses, with just over 1200mm and most 5 burner hobs are 700 or 900mm so it may be an idea to look at a domino gridle or something to make it look a bit better.
