burning smell from dishwasher
Home Forums Trade Technical & Spare Parts Forums Trade Technical Enquiries burning smell from dishwasher
Viewing 15 posts - 1 through 15 (of 19 total)
  • #43419
    fasetester
    hi guys have to look at a hotpoint dishwasher dwf50s their is a burning smell coming from it. any known fault to look out for thanks fasetester 🙂
    #277200
    Re: burning smell from dishwasher
    Module, motor, wall socket, heater wiring?
    #277201
    fasetester
    thanks martin for your reply. the husband said he does not think it is washing you can here a clicking sound and then the get the burning smell. possible jammed motor. if the washer pump bearing are gone . or a leaking shaft seal can any of the two be replaced thanks fasetester 🙂
    #277202
    Lawrence
    if you are getting a burning smell when it should be washing then its fairly certain the motor is knacked.
    Failing that it could be element coming on
    #277203
    fasetester
    thanks lawrence for the reply can the bearings and shaft seal be replaced . what would cause the heater to come on a blocked pressure vessal thanks fasetester
    #277204
    Lawrence
    I am not sure with regard to the motor seal kit I am looking at the same info as you and yes a blocked pressure system would bring the element on .
    #277205
    My money’s on the R.I.F.
    Mike.
    #277206
    fasetester wrote:thanks lawrence for the reply can the bearings and shaft seal be replaced . what would cause the heater to come on a blocked pressure vessal thanks fasetester
    The motor and circulating pump housing are sold seperately. The heater is the through type flow control therefore if the motor doesn’t work then the heater doesn’t come on.
    Enough on the speculation and best you call by and check it out eh? 8)
    #277207
    fasetester
    what is the rif mike fasetester
    #277208
    fasetester
    hi guys went to check it out. when trying to set program nothing would only light the 50 ligh on the left hand side. disconnected and removed base washer motor was badly rusted. and base plate motor smelt if it was
    frying it was leaking down into motor said she had it over six years and would go for new dishwasher fasetester.
    #277209
    timdowning
    Cor what alot of effort for no return. :rolls:
    #277210
    fasetester
    the all dont turn out the way you want what would you do tim fasetester 🙂
    #277211
    leavemetogetonwithit wrote:My money’s on the R.I.F.
    You were spot on there Mike. 😉
    #277212
    fasetester wrote:what is the rif mike fasetester
    http://connections.connect-distribution … uery=dwf50
    When you smell burning, it’s one of the first places to look.
    Mike.
    #277213
    fasetester
    at the washer pump mike fasetester 😕
